lhm240393807
how to boot software from ace file in ML605
hello
  I want to use compact flash to configure the ML605.  I generate the ace file including hardware and software with genace.sh
the content of genace.sh : xmd -tcl genace.tcl -jprog -hw ../SDK/SDK_Workspace_35/hw_platform_0/download.bit -board ml605 -target mdm -elf ../SDK/SDK_Workspace_35/hello_world_0/Debug/hello_world_0.elf -ace hello.ace
the software is a reference design "hello world". when I use EDK and SKD to configure the ML605. it works well
when I use the compact flash (ace.file) to configure the ML605. the hardware design is configured correctly by download.bit,  but the software "hello world " is not executed or booted
please help me out to boot software from ace file
robinliuy
Voyager
Voyager
Can you make it work to use .bit file with iMPACt?
Anonymous
Not applicable
The below link documents can be useful for your requirement
http://www.xilinx.com/support/documentation/boards_and_kits/xtp084.pdf --> ML605 Hardware set-up guide
http://www.xilinx.com/support/documentation/boards_and_kits/ug533.pdf --> Getting started with ML605 (SYstemAce configuration details als given)
http://www.xilinx.com/itp/xilinx4/data/docs/pac/genfiles3.html  --> Creating System system Ace programming file concepts
Kindly accept my post if you think it is useful to you
smirkel
I have the same problem. When I download and run the elf file from XMD, it works perfectly. When I generate the ace file the board gets configured, but the software doesn't start.
I had some projects working on XUPV2P from ace file with no problems, I'm new to the ML605 and microblaze.
Why does the genace say "*.elf does not contain start address.."? I just added "-start_address 0xB0000000" to the genace.opt file, the address of the ddr3 from linker script, with no results.
I'm using the default bootloop from the XPS.
I tried to initialize bram with the default TestApp_Memory and used the TestApp_Peripheral .elf file to make the ace and terminal output was only "-- E" as in "-- Entering main() --" from TestApp_Memory.
Ace file works if I use only bram, but my software is too big.
dragan.topalovic
hello
I have the same problem. Did anyone find some solution or  workaround?
dragan.topalovic
HI, we find solution.
By using XMD (mrd addr) command we compared ddr content
dowloaded from ace with elf disassembly end found out that the endinaess
is wrong (LE instead of BE - we are using mb_v8be). We investigated
little further and concluded that the problem is in genace.tcl in
procedure xmd_elf2svf which convert elf to svf file. Command
xconnect, we suppose, don't correctly propagate the parameter
cpu_version microblaze_8be from structure xmd_options and its pack
output file in litile endian instead of big endian. So we made a patch
and hardcoded cpu_version to microblaze_ (which is BE) in the
procedure call but preserved prefix and sufix svf files for
microblaze_8be. This resulted in an ACE file that successfully booted
the SW from DDR!
smirkel
I can't get it to work, maybe I didn't get it right.
Could you give the lines you changed in the .tcl file or the whole file?
