Visitor wazzanan
how to connect Zedboard with raspberry pi 3 using uart
I am traying to connect my Zedboard  with raspberry pi 3 using uart
I use for it uart cable that I use to connect with my pc
but it does not work.
In Pc I connect the cable to usb at my pc and I use ttyACM0 to check the output using minicom and it works
but in  raspberry pi 3  I connect the cable to usb at raspberry pi and I use ttyAMA0 but it does not work
do u hav any suggestion ??
thank u very much
Visitor wazzanan
Re: how to connect Zedboard with raspberry pi 3 using uart
@hbucher Thanks I got it but there is sth so funny maybe u could explain to me that
I change the file /boot/cmdline.txt from console= serial0 to console =/dev/ttyUSB0
and I restarted rpi
after I excute "dmesg"
I got sth else not what I posted in my previous post and it say that
[ 556.205238] usb 1-1.5: Product: Cypress-USB2UART-Ver1.0G
[ 556.205251] usb 1-1.5: Manufacturer: 2012 Cypress Semiconductor
[ 556.205263] usb 1-1.5: SerialNumber: 86500BD72E26
[ 556.210264] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ 896.128703] usb 1-1.5: USB disconnect, device number 11
[ 896.128992] cdc_acm 1-1.5:1.0: failed to set dtr/rts
I wrote
minicom -b 115200 -D /dev/ttyACM0
It works perfect
any explain !!!!!!!!!!!
Scholar hbucher
@wazzanan
Boot Raspberry Pi
Disconnect cable from Pi
Connect it back
run "dmesg"  on command line
Tell me what are the last lines
Visitor wazzanan
@hbucher Hi I think there is sth wrong I change the setting from rom ttyAMA0 to ttyUSB0
I hav not got any message on the minicom but when I check the led in Zedboard
it seems that It works very well
when when I write the instruction like u said I got error
I post what I got
do u hav any sugesstion about what could i do ??
[ 154.840094] usb 1-1.5: USB disconnect, device number 6
[ 307.929693] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
[ 308.045039] usb 1-1.5: New USB device found, idVendor=04b4, idProduct=0008
[ 308.045054] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=4
[ 308.045061] usb 1-1.5: Product: Cypress-USB2UART-Ver1.0G
[ 308.045068] usb 1-1.5: Manufacturer: 2012 Cypress Semiconductor
[ 308.045074] usb 1-1.5: SerialNumber: 86500BD72E26
[ 308.049442] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ 315.373389] usb 1-1.5: USB disconnect, device number 7
[ 315.373604] cdc_acm 1-1.5:1.0: failed to set dtr/rts
[ 323.549686] usb 1-1.5: new high-speed USB device number 8 using dwc_otg
[ 323.654493] usb 1-1.5: New USB device found, idVendor=0403, idProduct=6014
[ 323.654507] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 323.654514] usb 1-1.5: Product: Digilent USB Device
[ 323.654520] usb 1-1.5: Manufacturer: Digilent
[ 323.654526] usb 1-1.5: SerialNumber: 210248A49BD6
[ 324.726673] usbcore: registered new interface driver usbserial
[ 324.726729] usbcore: registered new interface driver usbserial_generic
[ 324.726777] usbserial: USB Serial support registered for generic
[ 324.734584] usbcore: registered new interface driver ftdi_sio
[ 324.734655] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 324.734917] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
[ 324.735045] usb 1-1.5: Detected FT232H
[ 324.736601] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
[ 513.800562] usb 1-1.5: USB disconnect, device number 8
[ 513.800901] ftdi_sio ttyUSB0: error from flowcontrol urb
[ 513.801248] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 513.801302] ftdi_sio 1-1.5:1.0: device disconnected
[ 517.109726] usb 1-1.5: new high-speed USB device number 9 using dwc_otg
[ 517.214754] usb 1-1.5: New USB device found, idVendor=0403, idProduct=6014
[ 517.214777] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 517.214790] usb 1-1.5: Product: Digilent USB Device
[ 517.214804] usb 1-1.5: Manufacturer: Digilent
[ 517.214816] usb 1-1.5: SerialNumber: 210248A49BD6
[ 517.218024] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
[ 517.218280] usb 1-1.5: Detected FT232H
[ 517.218864] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
[ 533.003225] usb 1-1.5: USB disconnect, device number 9
[ 533.003559] ftdi_sio ttyUSB0: error from flowcontrol urb
[ 533.004476] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 533.004535] ftdi_sio 1-1.5:1.0: device disconnected
[ 555.509729] usb 1-1.5: new high-speed USB device number 10 using dwc_otg
[ 555.614760] usb 1-1.5: New USB device found, idVendor=0403, idProduct=6014
[ 555.614785] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 555.614798] usb 1-1.5: Product: Digilent USB Device
[ 555.614811] usb 1-1.5: Manufacturer: Digilent
[ 555.614823] usb 1-1.5: SerialNumber: 210248A49BD6
[ 555.617966] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
[ 555.618238] usb 1-1.5: Detected FT232H
[ 555.618774] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
[ 1053.264739] usb 1-1.5: USB disconnect, device number 10
[ 1053.265077] ftdi_sio ttyUSB0: error from flowcontrol urb
[ 1053.265458] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 1053.265516] ftdi_sio 1-1.5:1.0: device disconnected
[ 1449.481215] IPv6: ADDRCONF(NETDEV_CHANGE): enxb827eb287fcf: link becomes ready
[ 1449.482071] smsc95xx 1-1.1:1.0 enxb827eb287fcf: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 1503.353058] usb 1-1.4: new high-speed USB device number 11 using dwc_otg
[ 1503.458062] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6014
[ 1503.458077] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1503.458084] usb 1-1.4: Product: Digilent USB Device
[ 1503.458090] usb 1-1.4: Manufacturer: Digilent
[ 1503.458097] usb 1-1.4: SerialNumber: 210248A49BD6
[ 1503.461697] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
[ 1503.461803] usb 1-1.4: Detected FT232H
[ 1503.462094] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
Scholar hbucher
@wazzanan So it is ttyUSB0
You can give persistent names for specific devices using udev
http://hintshop.ludvig.co.nz/show/persistent-names-usb-serial-devices/
Be sure you are using the right speed with your device. It is usually 115200 but minicom I think defaults to 9600. I use like
$ minicom -b 115200 -D /dev/ttyUSB0
Newbie wazzan
and I restarted rpi
It works perfect
any explainations !!!!!!!!!!!
Visitor wazzanan
and I restarted rpi
It works perfect
