Visitor lujie
how to run the zc706 2018.3 bsp with petalinux
I use BOOT.BIN and image.ug that comes with bsp on the zc706 development board. The version is 2018.3, and the following error occurs.
U-Boot 2018.01 (Dec 06 2018 - 09:38:54 +0000) Xilinx Zynq ZC706
Model: Zynq ZC706 Development Board
Board: Xilinx Zynq
Silicon: v3.1
I2C:   ready
DRAM:  ECC disabled 1 GiB
MMC:   mmc@e0100000: 0 (SD)
SF: Detected s25fl128s_64k with page size 512 Bytes, erase size 128 KiB, total 32 MiB
*** Warning - bad CRC, using default environment
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
Board: Xilinx Zynq
Silicon: v3.1
Net:   ZYNQ GEM: e000b000, phyaddr 7, interface rgmii-id
eth0: ethernet@e000b000
U-BOOT for xilinx-zc706-2018_3
ethernet@e000b000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Hit any key to stop autoboot:  4  3  2  1  0
Device: mmc@e0100000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
60183094 bytes read in 3266 ms (17.6 MiB/s)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Can someone help me?
Re: how to run the zc706 2018.3 bsp with petalinux
Things to check:
  • SD Card is formatted FAT32
  • image.ub and BOOT.BIN were procured/created from the same source.
  • Your BSP version matches the version of Petalinux you used.
You mentioned that you used Vivado 2018.3 but I see 2018.1 on the first line of your U-Boot log.
Things to check:
Visitor lujie
I use the petalinux 18.3 and zc706 bsp 18.3,and SD Card is formatted FAT16.
petalinux 17.1 and zc706 bsp 17.1 is useful.
Maybe the SD Card mast be FAT32
Mentor watari
Mentor
Hi @lujie
Whether u-boot requires formatted FAT32 or formatted FAT16 depends on 1st partition size.
If 1st partition size is under 32Mbytes, you can use formatted FAT16 as 1st partition.
If over 32Mbytes, you should use formatted FAT32 as 1st partition.
