how to supply 200MHz clock for xilinx DPHY IP application with VCU118 board clock source?
DPHY needs a pair of 200MHz differential clock.
how to supply at vcu118 board?
Re: how to supply 200MHz clock for xilinx DPHY IP application with VCU118 board clock source?
Hi @m006
VCU118 have system clock of 300 MHz and 125MHz Clock
Use the below sequence to derive the 200MHz clock from the system clock as follows.
 Differential System clock(300Mhz)   -> IBUFDS  -> BUFG -> MMCM to generate 200MHz clock.
Instantiation and description of all these primitives are given in Libraries use guide
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug974-vivado-ultrascale-libraries.pdf
Reply if you have any queries, Give Kudos and Accept as solution if you get one
can the two MMCMs be cascaded?
Hi @m006
Yes . The MMCM can be cascaded through the routing resources only and there is no compensation for routing delays .
Refer CMT to CMT connection in Ultrascale and 7 series clocking user guide
https://www.xilinx.com/support/documentation/user_guides/ug572-ultrascale-clocking.pdf
https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf
I believe your first query is answered ,Can you please mark it as accepted as solution ..Please let me know if you differ
and need further assistance .
