Observer kos8108
i want to find fmc cable ! plz
I am looking for fmc cable to connect to zcu102 board and vcu118 board.
9 " FMC To FMC Cable "
https://hitechglobal.us/index.php?route=product/product&path=18&product_id=56
I found the product on the link above, but it is difficult because the board list is not available.
Do you have a site i can buy, or can you recommend a product?
Visitor sthotakura
Re: i want to find fmc cable ! plz
On both the boards ZCU102 and VCU118 we have Samtech connectors ASP_134486_01
So, we need the mating connectors with the cable i.e  ASP-134488-01.
In the same link which you have provided, you can purchase any one of these two cables.
1.FMC-TO-FMC-9-88-88(9-inch cable)
2.FMC-TO-FMC-5-88-88(5-inch cable)
We have an option called buy online to purchase the same last column in the table.
Visitor sthotakura
The cables should be OK.  Make sure you are using compatible I/O standards on your boards.  The ZCU-102 defaults to 1.8V VCCO on the FMC banks.  Not sure about the VCU-118.
Observer kos8108
Thank you really much. Your reply was helpful.
Can I ask you one more question?
I found another product for the qualification comparison. Is this also compatible?
HDR-169468-01
https://www.digikey.com/product-detail/en/samtec-inc/HDR-169468-01/SAM9477-ND/6678214
Observer kos8108
HDR-169468-01
Visitor sthotakura
1.You can not use that because it is having  ASP-134486-01[Female] on one of the side and on another side ASP_134488-01(Male connector) this is fine to mate with either ZCU102 and VCU108 boards.
2.The problem is with ASP-134486-01(Female) connector is same which is on both the boards[VCU118 and ZCU102]we can not mate(Female and Female) this connector to any one of above-mentioned boards.
Note:
This type of cables is useful whenever you require one female and one male FMC requirements.
