`ilmb_cntlr_dlmb_cntlr' overflowed by 76560 bytes
can anyone help me how to fix this error,
Description Resource Path Location Type
region `ilmb_cntlr_dlmb_cntlr' overflowed by 76560 bytes PCI_HELLO C/C++ Problem
reshmaakhil
It indicates that program size now is bigger than the LMB size. Adjust the ILMB and DLMB size in the address editor page to make the program fit into it.
Please refer https://www.xilinx.com/support/answers/35619.html
Reshma
thank you for your response i did this already but i got same error
reshmaakhil
could you please share the block design? If your design is too large, then you may need to use external memories such as DDR.
Have you tried that too?
Reshma
NO i didn't tried with DDR
