isim12.1 not running on ubuntu11.04
Isim 12.1 is not running on ubuntu11,04.It is showing ELABORATING.Can you suggest why this problem and how can i handle it??
Hello "dashkirankumar",
Unfortunately, the Ubuntu OS is not a supported OS. The list of supported OS versions for the software tools is given at the following location:
http://www.xilinx.com/ise/ossupport/index.htm
I know that you are probably looking for any help from others who may have coaxed Ubuntu into working, but there are so many things that can go wrong in an unsupported OS that you may not realize you have a problem until late in your design cycle, and may have wasted a great deal of time going down that path.
OK, I hope this helps ...
Thank you.
