issue after porting project from SDK2016.2 to SDK 2019.1
I have project which is model in 2016.2 in xilinx version. I install 2019.1 and run that project. In ISE or Vivado all thing going well but when i launch it in SDK, it is not working and in project manger only i see hdf file folder, it nver show me stanalone_bsp_0 folder.
Can you guide me how to do it in SDK.
Were you able to try the steps mentioned except update to 2019.1?
I imagine the steps would be similar except use the versions you are asking about.
  1. Update the hardware to 2019.1
  2. Re-create the BSP project based on the new hardware definition
  3. Create empty application projects for your previous 2016.2 projects
  4. Import the source code into the empty application projects
Hi @nwp-100,
This forum discusses how to migrate from SDK2016.4 to SDK2018.3 and the steps are italicized below.
https://forums.xilinx.com/t5/Embedded-Development-Tools/Migrate-SDK-project-from-2016-4-to-2018-3/td-p/933591
I would recommend these steps:
  1. Update the hardware to 2018.3
  3. Create empty application projects for your previous 2016.4 projects
This will make sure that all the dependencies are accounted for.
Hope this helps!
Sincerely,
Courtney
Please don’t forget to reply, give kudos, and accept as a solution if you found this helpful!
I need for 2019.1 version, i working on that and install only 2019.1 xilinx version.
