Visitor sdlwz160
kcu116 Ethernet example design code
where can I get kcu116 Ethernet example design code? udp
Re: kcu116 Ethernet example design code
Hello @sdlwz160,
You can always generate your own design using IP catalog.
You can customize the IP as per your need from the GUI only and can review the code by opening IP example design.
Hope these helps.!!!
