ml403 pin description documnet
hi,
can some body please give me a complete description of the ml403 pin description documnet.
The following user guide document does not provide ddr,sram etc pin connections of v4 fpga.
http://www.xilinx.com/support/documentation/boards_and_kits/ug080.pdf
Thank you,
Randeel.
You can check the schematics to get to know the locations.
http://www.xilinx.com/support/documentation/boards_and_kits/ml401_2_3_schematics.pdf
Or refer to any existing reference designs to make out the connections.
Thnx.
