Visitor tanay.rtpl
need help in spartane 6
i have a spartane 6 Fpga sp601 evaluation kit and its fpga got burnt due to high power supply, so we change the fpga and its power ic also (LINER LTM4616V) but now i am unable to load program in fpga. So any body can tell me why this is happening?
Does its FPGA needs any boot before placing in the board?
Scholar u4223374
Re: need help in spartane 6
Lots of things could have been damaged by an over-voltage event. Particular ones that could be relevant to configuration are the FPGA decoupling capacitors (6.3V maximum), the two flash chips, the other power supplies (there are a couple), or the embedded USB-JTAG circuitry. There's also the usual risk of getting a poorly-soldered BGA chip.
Have you verified that all power supplies are providing the right voltages now? What happens when you try to load a program?
Visitor tanay.rtpl
Yes, the power was same as mentioned in the board (means at 3.3V and at 2.5V they were exact at respective places) but then too its unable to upload bitream. Even in device manager it shows that some new hardware device is found but then too its unable to upload.
