Visitor a_saberi
problem in filtering input signals []Illegal Period, This blocks attempts to set period that is a non-integer multiple of the system rate Error occurred during "Block Configuration".
HI Xilinx team,
   I am using Vertex5-LM506. And I'm trying to implement "Digital TDM-FDM translator with multistage structure" which is telecommunication one. by Xilinx package on simulink [MATLAB],
  In the paper, I need to implement  filter
the following is the error thst I receive:
Let me describe what I did:
I have system generator with 66.667 MHz pulse and 1/8122 sampling period
I have Sine input that is 1000Hz and has sampling rate of 1/8192
The input unit has also 1/8192 sampling period
Then ......
error ..... it mean that there is problem with my period, what time of setting I can do keep in original setting of sampling 1/8192 untouched and get the result?
thanks in advance
Best
Ali
Re: problem in filtering input signals []Illegal Period, This blocks attempts to set period that is a non-integer multiple of the system rate Error occurred during "Block Configuration".
If it's possible, please open a new thread on the DSP Tools board ( http://forums.xilinx.com/t5/DSP-Tools/bd-p/DSPTOOL ) and attach your model.
@a_saberi wrote:
HI Xilinx team,
Then ......
thanks in advance
Best
Ali
Cheers,
Jim
