gilarirmbabu
problem with interfacing ADC with spartan 3E starter board.....
hi, i am trying to interface the onboard Amplifier and ADC. i am getting correct output for amplifier by reading AMP_DO signal(whatever the gain i am setting i am getting it on AMP_DO). but there is no response from ADC. ADC's digital outputs is always high for all input analog voltages . i know dont what is the problem. please help...i am entirly new for this.also trying this for longtime.
with regards,
G.R.Mahendra Babu
gilarirmbabu
can anyone give the solution?
regards,
Mahendra Babu G.R.
research_opl
i am also facing the same problem were you able to solve can you give your suggestion.
krlos15
did any of you get to a solution??? I have the exact same problem :
Anonymous
Not applicable
HI
S3-E Starter kit is using LTC 6912-1 amplifier. The LTC6912-1 provides two independent inverting amplifiers with programmable gain. The purpose of the amplifier is to scale the incoming voltage on VINA or VINB so that it maximizes the conversion range of the DAC, namely 1.65 ± 1.25V. For programmable gain settings please sea table 10-2 in ug230.pdf. The gain required to set as per voltage range of VINA or VINB. For more details please refer chapter-10 of ug230.pdf.
If it is not clear please use our  Worldwide Technical Support
Open Web Case
http://www.xilinx.com/support/clearexpress/websupport.htm. So that one of our engineer approach you.
With best Regards
Mahesh
kenneth_lee
hi, may i know that have you found the solutuion of the ADC that show all output with high state, now i facing this problem also, if you able solve it can you please tell me how and why?
scrts
A bit off-topic question:
do You configure programmable gain amplifier once on startup(which is quite difficult I suppose?) or send configuration data constantly after power up?
rago822
please let me know as i am also facing the same problem
eteam00
Professor
Professor
@rago822
How do you know your problem is the same?  Are you using the same ADC and amplifier?
- Bob Elkind
SIGNATURE:
Summary:
rago822
I am also using the same adc and the same programmable pre amplifier on  the boar. Kindly help me with the problem
petal1
Check if the other decives on the spi bus are disabled.
