query about max voltage that can be applied to adc on spartan 3e
I would like to know what is the maximum voltage that can be applied to the analog capture circuit on spartan 3e starter kit which includes the ltc6912 and the ltc1407a. I want to apply 4.5 v to the input. Is it possible?
Anonymous
Not applicable
The analog capture circuit inputs are connected operational amplifier (LTC6912). The data sheet of LTC6912 can be found in http://cds.linear.com/docs/Datasheet/6912fa.pdf .
In Spartan-3E starter kit circuit LTC6912 supply voltage pin connected to 3.3V supply. So you can not apply 4.5V to the input.for correct operation
Mahesh
Kindly accept any one of the post which you think more useful to you
To forum moderator: Please KUDO
Instructor
Instructor
If you can't search for a datasheet, read it, and understand it...  you've got troubles ahead.
LTC6912  input range is rail to rail.  VCC rail is 3.3V on Starter Kit board, so that's your limit (3.3V).
LTC1407  fed by LTC6912, so specs on this part aren't that interesting for your purposes.
Yes, but device failure will likely result, and you'll be outside the "linear" input range.  So the answer is really NO.
-- Bob Elkind
SIGNATURE:
Summary:
Anonymous
Not applicable
Mahesh
