Participant santosh_ts
"pack dropped, no space" after transmitting for 7.35 hrs every 10ms
Hello all,
I am transmitting UDP packets every 10ms on all 8 ports using FMC connector . I have used FIFO in vivado design.
The starnge issue is after 7.35 hrs of duration i am getting Pack dropped no space error in the function
static err_t low_level_output(struct netif *netif, struct pbuf *p)
SYS_ARCH_DECL_PROTECT(lev);
err_t err;
struct xemac_s *xemac = (struct xemac_s *)(netif->state);
xaxiemacif_s *xaxiemacif = (xaxiemacif_s *)(xemac->state);
#ifdef XLWIP_CONFIG_INCLUDE_AXI_ETHERNET_DMA
* With AXI Ethernet on Zynq, we observed unexplained delays for
* BD Status update. As a result, we are hitting a condition where
* there are no BDs free to transmit packets. So, we have added
* this logic where we look for the status update in a definite
* loop.
XAxiDma_BdRing *txring = XAxiDma_GetTxRing(&xaxiemacif->axidma);
#endif
int count = 100;
SYS_ARCH_PROTECT(lev);
while (count)
/* check if space is available to send */
if (is_tx_space_available_axi(xaxiemacif))
_unbuffered_low_level_output_axi(xaxiemacif, p);
pbuf_free(p); // added
err = ERR_OK;
break;
else
#if LINK_STATS
lwip_stats.link.drop++;
#endif
process_sent_bds_axi(txring);
#endif
count--;
if (count == 0)
print("pack dropped, no space low_level_output_axi\r\n");
err = ERR_MEM;
SYS_ARCH_UNPROTECT(lev);
return err;
Can anyone please help me out why i am getting this error ?
Thank you all in advance.
