tchin123
sfp connector cage nomenclature SFP (0,1,2,3) for Xilinx zcu102 development board
On the ZCU102, there is a 2x2 quad connector and cage assembly (R-OP-008080-6-F-N-26-F63) that accepts 4 SFP modules.
is there a drawing that display which of the quad module represent SFP0, SFP1, SFP2, SFP3 in respect to the 2x2 cage
Also on the ZCU106 there is a 1x2 dual connector assembly that accept 2 SFP module, Which one is SFP0 1nd SFP1 (right or left)
tchin123
does anyone has info on these dev bd (zcu102, 106)
kdeshwal
Hi @tchin123 ,
Check the schematics of zcu102 and zcu106 which is XTP-454 & XTP-469 respectively.
You will find the required details in these schematic.
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
tchin123
unfortunately the schematic doesn't show the physical location for each SFP module
anatoli
Hello @tchin123 ,
Please download and check the Allegro and the Gerber files for each board and that should give/show you the info you are looking for:
https://www.xilinx.com/products/boards-and-kits/ek-u1-zcu102-g.html#documentation
https://www.xilinx.com/products/boards-and-kits/zcu106.html#documentation
Check the Gerber file and that has a .pdf version, where you'd get the info you are looking for:
e.g. ZCU106:
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
And I would also normally expect to see the marking on the SFP cage itself, as in my example screenshot below, that was taken from the KCU105 board. Do you see the same on ZCU102/106 boards?
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
tchin123
the zcu10, 2x2 cage doesn't come with any front plate nor any designation marking
