Visitor donwaltman
spartan 6 output drive
       I'm using the SP605 and getting very slow slew, i.e. rise and fall times of over 2uS where I cannot even drive a serial clock to one input at 800k.  I first was trying to drive the SCLK input on Maxims 11040 ADC on their Spartan6 daughter card.  I then rerouted the output to header J5 on the SP605 where the output is level shifted by U52, TXB0108 with little change.
       I then instantiated an OBUF with no change.  Then I put the following attributes info the UCF:
IOSTANDARD = LVCMOS15   (I used LVCMOS33 when driving the MAX11040)
DRIVE = 16
SLEW = "FAST"
No change.  I also have the same problems on my other outputs, CS and DOUT.  I would almost think the chip or board is faulty, but there may be something I'm missing.  Can anyone help?
Thanks, Don
Instructor
Instructor
Re: spartan 6 output drive
To sum up, after 29 posts in this thread:
The appearance of a problem was due to either faulty scope probe or incorrect scope setting.
Agreed?  If this problem has been resolved, please mark the thread as 'solved'.
-- Bob Elkind
SIGNATURE:
Summary:
Professor
Professor
A few things:
1) How are you measuring the rise and fall times?  It is possible for example to get
confused when looking at a digital oscilloscope when looking at periodic signals
while sampling at a slower rate than the signal bandwidth.
2) Have you looked at the Vcco to the driving banks?  If this has jumpers on your
board, make sure they're correctly configured to supply the proper voltage for the
standard you choose.  Just setting IOSTANDARD to LVCMOS33 does not magically
supply the pin with 3.3V.
3) Where are you scoping the signal with the slow rise time?  At or near the FPGA?
Can you break the connection to the load and see if the slew rate becomes fast?
-- Gabor
-- Gabor
Visitor donwaltman
1) The scope is sampling well above the clock rate- I plugged in a 2M square wave and viewed just to be sure.
2) It does seem like there could be a power supply issue, but there are no jumpers for such.  Also, I used 1V5 when alternately driving an onboard level shifter and got the same results on the output of the level shifter.
3) Originally the signal was routed directly to the pins of an ADC.  The pins are very small, would be hard to lift, so I rerouted the signal to the level shifter I mentioned in 2) above.  The FPGA output will neither drive the ADC pin or the level shifter pin without a ridiculous amount of skew.
Thanks for the help, but still stuck.
Scholar austin
d,
What are you driving?  A large capacitive load will slow down an output...
You mentioned you also measured the output of a level shifter, and it was slow, too?  If everything is slow, then it isn't the FPGA.
To measure a 1ns rise time, you need (at least) a oscilloscope with a bandwidth of more than 3 GHz..
Often oscilloscopes are just too slow (limited bandwidth) to measure transistion times.  What is the badwidth of the oscilloscope you are using?  Are you using a scope probe with the same bandwidth specification?
http://en.wikipedia.org/wiki/Rise_time
Austin Lesea
Principal Engineer
Xilinx San Jose
Instructor
Instructor
You are right, of course, Austin...  but...
1.  350-500MHz bandwidth scope is good enough for most digital logic work (but not PCIe or SATA).
2.  The MAX11040 A/D has a max SPI clock rate of 20MHz.  Signal rise/fall times of 5nS should work fine.
3.  The measured risetime was 2uS.  A 10MHz scope is good enough to measure 2uS edges.
On the other hand:
4.  When checking for signal integrity issues (e.g. clock edges), a 10MHz scope isn't good enough.  A 500MHz scope is good enough for edges of signal with toggle frequencies of up to about 100-200MHz (you don't fall of a cliff, but you do slide down a not-so-slippery slope).
I mention this for the readers who might be scared away or discouraged because they don't have have a $45K scope (probes not included).
To donwaltman, and others:
There is probably something simple at fault, if you are seeing 2uS (sluggish) signal edges everywhere.
Do you have much experience designing and troubleshooting digital logic?  Without knowing you or your background, we could spend many many forum posts discussing scope setup, probe techniques, reading the fine manual and schematics, reviewing all the jumpers, etc. etc.  If you are inexperienced, then it is helpful to methodically review each of these steps.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor donwaltman
Ok, the problem is not the scope.  My THS720 is 100Mhz and my serial clock is 800k.
I routed the signals to J55 of the SP605 for analysis and got distortion with huge rise and fall times.  The signals pass through the TXB0108 Level Translator prior to J55.  I went directly to the chip and found the FPGA outputs to be fine (rise time < 50nS with "slow slew") at the inputs of the TXB0108, but the corresponding signals on the output pins to be trash.
What is even weirder, is that I have a translator (MAX3002) on the Maxim ADC board that is doing approximately the same thing and therefore my signals are never making it to the ADC.
Both translators are auto-detect bidirectional.  Has anyone else had bad experiences with these things?  I checked all chip voltages including the enable.  Am I a moron that I can't get a level translator to work?  Then again these things should be so transparent that I'm not aware of them.
Any comments concerning the functionality of these kind of chips would be helpful.
Thanks, Don Waltman
Instructor
Instructor
Would you please re-summarise where you find rise/fall times to be excessively slow?
Does this only occur at the TXB0108 buffer, on the side which is not connected directly to the FPGA?
What signal/connections combinations seem to be OK?
-- Bob Elkind
SIGNATURE:
Summary:
Visitor donwaltman
The FPGA side of the buffer is great.  The unloaded output side is crap.   Only 4 IOs out of 8 are used.  All 4 give me crap for output.  I have pics of input vs output waveforms that I could send tomorrow if needed.
Professor
Professor
Since this seems to be an issue with the level shifters, can you send a diagram of this
part of your schematic?  It is worth double checking that you meet the requirements of
the shifters, e.g. Vcca < Vccb, OE referenced to Vcca and active.  Note that the turn-on
time from OE is very long - 1 us.  Toggling OE could cause the sort of timing you see.
-- Gabor
-- Gabor
Visitor donwaltman
Page 4, Figure 1A, U5
Visitor donwaltman
I sent you the one on the Maxim ADC board.  Here is the TXB0108 on the SP605.  P44 of the user guide
Instructor
Instructor
The SP605 User Guide does not include board schematics.  And it's only 17 pages long.
The TXB0108 buffers are on page 35 of the SP605 schematics.  They do not connect to the FMC/LPC connector.
The FPGA directly drives the LPC connector, no buffer involved.
The Maxim board has its own level translator, a MAX3002.
So...  probing the TXB0108 doesn't help much.  What signals were you probing, again?
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
From your initial post in this thread:
... I then instantiated an OBUF with no change.  Then I put the following attributes info the UCF:
DRIVE = 16
SLEW = "FAST"
You should drive the Maxim daughter board directly from the FPGA, using LVCMOS25 IO standard.
Except for the (3.3V, open-drain) I2C SCL/SDA lines.
All the interface signals are buffered on the Maxim card, expecting 2.5V swings.
The Spartan-6 IO bank which connects to the LPC connector has VCCO=2.5V, which is correct and consistent with the Maxim daughter card.
-- Bob Elkind
SIGNATURE:
Summary:
Professor
Professor
The guide he posted is the wrong one.  You need the SP605 Hardware User Guide, p.44 which
shows some GPIO to a 6-pin header.  The level shifter appears to be on all the time (provided
that the supplies are connected as in the diagram - many eval kits have jumpers in line with
the bank supplies).  However there are also 200 ohm series resistors on each output wire,
which could server to slow the circuit down more.
-- Gabor
-- Gabor
Visitor donwaltman
You are right, the TXB0108 is irrelevant to my application.  I only referred to it because I discovered that it also had nearly the same problem when I used the J55 connector for troubleshooting.  What are the chances of having to separate level shifters that don't work?  I wanted to see if anyone else could possibly see any common denominators.
Instructor
Instructor
Let's re-establish the baseline.
What IO Standard and drive level are you selecting for FPGA output pins which directly connect to the LPC connector (and more specifically, the outputs among the 8 non-I2C signals used by the Maxim board)?
And what do you measure for rise/fall time on these 8 signals?  Do all 8 have similar rise/fall times?
Have you measured and verified the supply voltages on the Maxim board?
-- Bob Elkind
SIGNATURE:
Summary:
Visitor donwaltman
The outputs to the TXB0108 are unloaded except for the scope so the series R shouldn't matter.  I suppose I will get a new maxim eval board and hope it works.  I'm tempted to jump over the max3002 level shifter and go directly to the 3.3 ADC with 2.5V, but I'm afraid of damaging the FPGA.
Instructor
Instructor
This is a lot of work, and it's too easy to break something.  I would suggest troubleshooting the straight-stick standard configuration.  It's not that complex, and if you were convinced that the Max3002 was broken you wouldn't be posting this thread.  Right?
-- Bob Elkind
SIGNATURE:
Summary:
Visitor donwaltman
I'm currently using 8mA drive with slow slew.  There are three signals output from the FPGA- SCLK, CS and DOUT.  All are distorted (after the shifter), e.g. my 800khz serial clock never reaches zero and is nearly indistinquishable because of the skew.
Visitor donwaltman
I don't see any other possibilities other than a broken 3002 except maybe a broken 11040 ADC.  However, Maxim like Xilinx is a reputable company and they don't put out trash, so I'm hestitant to rest on those conclusions.
Professor
Professor
 They probably weren't trash when they left Maxim.  It is possible that the 3002 was damaged by ESD
or momentary power supply overvoltage.
-- Gabor
-- Gabor
Instructor
Instructor
After the MAX3002 shifter?  (it's important to be very specific in forum posts)
Did you verify the power supplies on the Maxim board?  All of them?
Next would be to probe the pins of the MAX3002 device.  After the supplies are verified.
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
It is possible that the 3002 was damaged by ESD or momentary power supply overvoltage.
The MAX3002 is rated for 15KV ESD tolerance.  That's pretty good.
Here's another thought:  very carefully inspect the MAX3002 device, at position U5 on the Maxim board.  Make sure it is marked MAX3002, and not MAX3000 or MAX3000E.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor donwaltman
I checked the supply for the VL side (2.5V) and for the VCC side (3.3V) and the enable (2.5V) directly from the pins on the chip.  The inputs and outputs were also read directly from the chip pins.
There are no power supplies on the  Maxim board; it's all supplied from the Xilinx SP605.
Chip damage could have occurred, however I wouldn't think that all three in/outs would be damaged the same way and I have not powered the board externally, only from the SP605.
It almost seems like this bidirectional design may have its pecularities but I wouldn't think they would put it out there if it were that unreliable.
Visitor donwaltman
3002, did it
Instructor
Instructor
3002, did it
Well, unless your scope inputs are set to 50-ohm input term instead of 1M-ohm, I have no brilliant ideas left.
If it was my board, I would fire up a soldering station and start lifting pins for further troubleshooting.  I wouldn't recommend that for anyone else.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor donwaltman
Well thanks for all the help.  It at least gives me some confidence that I'm not crazy.  Tomorrow when I get access to the fine tip iron, I may lift the SCLK ADC pin.
It's only an $80 eval board, but my greatest fear is getting another one and the same freaking thing happening.
Thanks again for the help.  I'll post any significant findings.
Visitor donwaltman
     Just an update on the MAX3002 level changer where the input signals were steep-edged and square and the output was crap.  Bob Elkin had mentioned a scope probe, but the same probe had accurately measured the inputs and just to be sure I measured the resistance going into the scope through the probe and got about 10M.  After narrowly escaping state-mandated commitment, I tried another probe just for the hell of it.  The signal looked improved but still distorted.  I put the probe on 10:1 and got a perfect signal.
    I'm guessing the original probe had a capacitive load, but I was still shocked that the load of a good probe on 1:1 was too much for this chip.  I guess the 6k output impedance was a clue.
    I think the manufacturers should do a better job of specifically documenting this in their data sheets.
    Thanks to all who helped.
Instructor
Instructor
-- Bob Elkind
SIGNATURE:
Summary:
