system.hdf & .mmi files of AMS101 evaluation board for 7series
system.hdf and .mmi files are not available in the design file of AMS 101.Please send me the same file or the image of block design(IP Integrator block diagram.).
kvasantr
Hello @muhammad_shan007
for which board are you testing AMS101 card on ?
I will try to re-create HDF and mmi file.
Thank You
My board is artix 7 ac701
