hao.zhang2
the versions of documents and design files for RFSoC ZCU111
I just start to touch the ZCU111 board. From the link of
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0037-zynq-ultrascale-plus-rfsoc-hub.html
there are some documents and design files of version 2018.2 or 2018.3. And there are some new documents of version 2019.1 on the website, but I can't fine the design files matching to the documents of version 2019.1.
Could you please send me the link about the design files of version 2019.1? Or the same design files as version 2018.2?
Thanks a lot for your help.
Best regards,
Hao
ddn
Hi @hao.zhang2 ,
Visit this https://www.xilinx.com/products/boards-and-kits/zcu111.html#documentation .
Then click on see all versions, for the Documents which has that option of see all versions. There you will find corresponding Documents and there corresponding Design files like below image:
Hope this helps.
Deepak D N
Please Kudo and Accept as a Solution, if it helps.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
Hi @hao.zhang2 ,
Hope this helps.
Deepak D N
Deepak D N
hao.zhang2
Dear Deepak,
Thank you very much for your information and help.
Best regards,
Hao
