two FPGAs in board part file
we are following the instructions in UG895 2015.1
but we add second as FPGA as instructed in UG895, eg first one part0, second fpga part1
then how can we choose wich one is active in vivado?
Project summary shows that
:part1:
is active, but we can connec to intefaces for part0?
some thing is still broken, or what are we doing wrong?
@trenz-al The multi part FPGA board file is not supported with the 2015.1.
-Pratham
are you defining the connections between fpgas and other components ? checkout "connections" on page 123. There needs to be a way to group other components and "fpga" components together and connections seems to be it.
yes of course we have defined connections to both fpga and jtag chain to both fpgas and done all we can figure out
but it seems that the "partx" that is found in the XML as last one is always used as if it would be only one FPGA in the board file
part0
part1 ...
in this case Vivado always shows "part1"
if we only SWAP the order of appearance of the FPGA component
part1
part0
in this case Vivado always shows "part0"
if we manuall try to override the board_part to the FIRST component listed in board part file like this
set_property board_part trenz.biz:tec07/0-01-160:part0:1.0 [current_project ]
get_property board_part [current_project ]
trenz.biz:tec07/0-01-160:part1:1.0
Then Vivado refuses to set the board part properly, we set the property as :part0:1.0
but when we then immediatly read it back it is reported :part1:1.0
there is no warning or error, Vivado is just silently ignoring any attempts to set fpga component that is not listed as last one board file
seems like bug, or there is some unlnown and undocumented trick involved
after you read in the board xml, what does vivado report for board_part ? I think it should have two entries instead of one. I haven't tried it but if it is not reporting two (or N) and allowing you to select which part you are working with maybe the support is not fully there for multi-part boards yet.
there is no way to select between 2 FPGA as much as I can see
2015.2 ?
@trenz-al I am checking this with concerned person.
-Pratham
thank you, please do, then it is maybe not necessary for us to open webcase.
We are preparing 2015.1 board files and we have product with 2 identical Kintex FPGA's. It would be really nice to be able to define then correctly.
Right now we are using some workarounds :(
-Pratham
