verilog help with clock divider
Hi Everyone,
Sorry if this is a simple question but I'm struggling with this issue - I'm using a coolrunner II and thought I would try and learn verilog by converting the VHDL example in the handbook - The problem is that I can not get a clock divider to work. The issue is that I can see in ISim that clock_div_int is changing as expected but it never triggers the always loop and so clock_div remains "x".
module clock_divide(    input clock_osc,    output clock_div    );
reg [9:0] count;
wire clock_div_int;
count =10'b0;
CLK_DIV16 CLK_DIV16_inst ( .CLKDV(clock_div_int),  .CLKIN(clock_osc));
always @(posedge clock_div_int) begin
count <= count + 1;
end
assign clock_div = count[9];
endmodule
Many thanks
Ross
Re: verilog help with clock divider
Ross,
Don't you want to do something on the input clock? You have "always @(posedge clock_div_int)" which I thought was your output?
Where do you change the state of your output?
Austin Lesea
Principal Engineer
Xilinx San Jose
Instructor
Instructor
Are error messages generated when synthesising your design?
Couldn't find a 'handbook', perhaps you could post a link, or (better) post the original VHDL code.
You're new to Verilog design, right?
Here's a quick example of a clock divider:
reg [3:0] count;  // clock divider counter
reg       clk_div;  // clock divider output
always @ (posedge clock_in)
  begin
    if (count==4'b1001)  // divide by 10
       count <= 4'b0000;  // reset to 0
    else count <= count+1;  // increment counter
    clk_div  <=  (count == 4'b0000);  // counter decoded, single cycle pulse is generated
  end
-- Bob Elkind
SIGNATURE:
Summary:
So I found the solution - Thanks everyone - Very very simple mistake.
I screwed up the initilization of the count - I needed to:
initial
    count = 0;
Hi I made a really silly error. Apologies - I'm only a few hours into learning verilog - forgot to initialize count.  For those interested the handbook I'm refering too is the handbook that comes with the coolrunner-II CLPD starter kit.
Professor
Professor
reg [9:0] count = 0;
wire clock_div_int;
// count =10'b0; This assignment is not within a process block (wasn't there an error?)
count <= count + 1;
end
endmodule
This should help (simulation will not "increment" an 'X' value.  You need to start from a known value like zero)
However if you have synthesized the code I expect it would have worked...
-- Gabor
Edit:
Just saw that you beat me to the post  :-)
Maybe next time you'll work a little longer before asking the easy questions...
My method is equivalent to the "initial" statement.  You could also have introduced a reset
signal to accomplish the initialization.
-- Gabor
this is not a clock divder. Actually it's a clock multiplier or, say, frequency divider.
