jahnavijanu.y
vivado 2018.3
hi,
i am new to FPGA ,i have to work on kc705 , can we use vivado 2018.3 version?
and there is any license  required for this to download vivado 2018.3 ?
thanks in advance,
regards,
jahnavi
katsuki
Hello
The FPGA on the KC705 is the XC7K325T, and to create the XC7K325T design, you need the Vivado Design Edition or System Edition.
Vivado Webpack is not supported XC7K325T.
https://www.xilinx.com/products/design-tools/vivado/vivado-webpack.html
https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html
Please refer UG973 Vivado Release Notes.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug973-vivado-release-notes-install-license.pdf
Yoichi
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
katsuki
Hello
Yoichi
