Visitor zozo
voltage required for a chip
hi community, what is the required voltage for the Zedboad (7-series), i mean the whole chip? or the minimum required voltage for advanced FPGA?
thank you for replying as soon as possible
regards
Re: voltage required for a chip
@zozo-Please clearly specify which voltage that you are referring?
If you are asking about PL IO banks VCCO then it depends upon IO standards you defined for that bank. The default IO standard is LVCMOS 3.3V. So the default VCCO is 3.3V.
Visitor zozo
hi @umamahe, thanks for replying, i mean for example in vivado when i designed my architecture so is needing a voltage to work on or we can say to be powerd. i'm talking about all the chip ( all the IPs the maximum voltage that need to work)
Scholar u4223374
Modern FPGAs need several different power supplies. On the Zedboard, you have:
1.0V - VCCINT (PL fabric), VCCPINT (PS), VCCBRAM (BRAM)
1.5V - VCC_DDR (RAM interface)
1.8V - VCCAUX (configuration interface), VCCPAUX (PS configuration interface), VCCPO_MIO1 (PS I/O)
3.3V - VCCPO_MIO0 (PS I/O), VCCO_13 (PL I/O), VCCO_33 (PL I/O), VCCO_0 (configuration interface I/O)
VADJ - VCCO_34 (PL I/O), VCCO_35 (PL I/O)
VADJ can be set to 1.8V, 2.5V, or 3.3V using a jumper.
The Zedboard itself just accepts 12V, which then powers everything else.
Hello @zozo,
You can consider using the XPE.
https://www.xilinx.com/products/technology/power/xpe.html
You can use the values found from VIVADO after design implementation and put them under the sections given in the excel sheet
to get the power consumption by chip.
Hope this helps.
Thank you.
