want to Learn interfacing of zynq 7000 with Ethernet by PL
I want some basic tutorials or any small simple project based on interfacing of Ethernet with Zynq 7000 (Zedboard)  to learn.
I tried to find tutorials based on ethernet but all those tutorials were based on PS logic but i want to implement it with PL. Anyone can guide me that how can i get a tutorials or any guide to start ethernet interfacing with PL in zynq 7000.
MicroZed Chronicles
http://adiuvoengineering.com/microzed-chronicles/
Enjoy,
Some people order a wheel then say 'can I have it square?'
In principle, there is no problem in having ethernet on the PL. Many projects do that. There is an IP for that. Green lights so far.
What I can't see is why Zynq? At the end you will need a board, and all Zynq boards with Ethernet will have it connected to the PS... I used Artix-7 for 10GbE in the past, they have the GTX transceivers that can be used for Ethernet, but with Zynq-7000 you need at least the 7030 to have transceivers (see the product selection guide). Otherwise you will need an external PHY (additional IC) and interface it with GMII or other protocol. Such a board probably doesn't exist because it makes no sense...
