pagru
write count != nBytes(0), rc = 20000015 and Boundary Scan finds many unknown devices
Hello everybody,
lately I started my journey through the FPGA world. I tried to obtain some practical experience using the SPARTAN-3E Starterkit.
I've solved the first tutorial "counter", and put it in the XC3S500E on my development board (starter kit).
It was easy and worked without any errors. The impact service had no problems to find three known devices on the board.
So I tried to make some further steps. :smileyhappy:
But now, the problems began:
The "Boundary Scan" finds either one unknown device or many unknown devices.
The console window says:
 Checking cable driver.
 Driver file xusb_emb.sys found.
 Driver version: src=1029, dest=1029.
 Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
 Cable PID = 0008.
 Max current requested during enumeration is 74 mA.
Type = 0x0004.
 Cable Type = 3, Revision = 0.
 Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1303.
File version of C:/Xilinx/10.1/ISE/data/xusb_xlp.hex = 1303.
Firmware hex file version = 1303.
PLD file version = 0012h.
 PLD version = 0012h.
PROGRESS_END - End Operation.
Elapsed time =      2 sec.
Attempting to identify devices in the boundary-scan chain configuration...// *** BATCH CMD : Identify
write count != nBytes(0), rc = 20000015.
write cmd failed 20000015.
PROGRESS_START - Starting Operation.
Identifying chain contents ....write count != nBytes(0), rc = 20000015.
'1': : Manufacturer's ID =Unknown
INFO:iMPACT:501 - '1': Added Device UNKNOWN successfully.
'30': : Manufacturer's ID =Unknown
INFO:iMPACT - iMPACT quit the Identify Chain because it detects there are
at least 30 'UNKNOWN' type devices on the chain.
Please check the hardware settings and retry!
Elapsed time =    139 sec.
:smileysad:
Why does this error appear and how can I solve it?
pagru
Thanks you your help.
Spending more and more time finding the problem, I tried to use another JTAG program adapter. Result: No problems!
So, the main problem seems to be the on-board usb-programmer.
May be, one day I will know, why it won't work.
