08-15-2017 02:01 PM
2016.4 trying to rebuild bitstream, but failed with this message:
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted: pl_eth_10g_i/xxv_ethernet_0/inst/i_pl_eth_10g_xxv_ethernet_0_0_top_0/i_pl_eth_10g_xxv_ethernet_0_0_CORE (pl_eth_10g_xxv_ethernet_0_0_xxv_ethernet_v2_0_1_mac_baser_axis_hsec_cores)
I have Design_Linking IP license available.
Any hints?
08-15-2017 09:04 PM
You can use the evaluate option from below link to generate the Hardware Evaluation license so that you can generate a time limited bit file for the xapp and test it on your board.
https://www.xilinx.com/products/intellectual-property/ef-di-25gemac.html
08-15-2017 09:00 PM
Hi @legendbb
A Simulation-Only or Design-Linking license for a LogiCORE IP Core is an evaluation license key that allows you to run through the entire design flow and perform both pre- and post-implementation simulation. However, you cannot generate bitstreams for designs that contain LogiCORE IP Cores enabled by a Simulation Only license.
08-15-2017 09:04 PM
