mavoro
xdc master file for ZCU111 Board
I am following the steps in a tutorial and I am supposed to make changes to the master xdc file. Digilent supplies a master xdc file for the board used in the tutorial which can be downloaded.
I am using a ZCU111 board, so I wondered where I could find xilinx's master xdc file. I didn't find any yet, does anyone know where to find it, or how to side step the problem? Thank you.
(The Tutorial I am following is https://reference.digilentinc.com/learn/programmable-logic/tutorials/zybo-creating-custom-ip-cores/start)
Tags (3)
florentw
HI @mavoro ,
Go on the ZCU111 page:
https://www.xilinx.com/products/boards-and-kits/zcu111.html#documentation
The xdc file is under XTP508 - ZCU111 Schematics (v1.0) :
florentw
HI @mavoro ,
mavoro
Perfect, thank you!
lalitbhambhani
I found an error in the top level XDC file. See image.
pthakare
Hi @lalitbhambhani
Thanks for pointing this typographical mistake. @panantra will file the CR to get this corrected.
Reply if you have any queries, give kudos and accept as solution
