karimia
xm105 compatibility with zcu102
I'm using zcu102 board rev1.0(I checked it with vivado suite 2018.3) and wanna use xm102 card.
I saw the posting that xm105 supports the zcu102 board. but in my case, among the 3 leds only one is on
not vadj good and pwr good, they are off,
First I checked the connection TDI-TDO. they are connected.
And then I checked the JTAG or UART connection with device manager and vivado suite. it works.
There are two ways for setting XM105.
though I know zcu102 is rev1.0, tried both.
SCUI.exe
When I clicked the  VADJ_FMC voltage button, all the buttons are disabled including FMC tab
(Same as it shows me disabled buttons, when I clicked the FMC-set VADJ-Bootup-set VADJ to 1.8V or others)
So I tried also in tera term, and did setting what the tutorial indicates.
but nothing appears.
Anyone got through this problem, please help me
Best Regards
thakurr
Hi @karimia
The langauge for OS can be changed as below:
2016.4 SCUI can be found at xilinx.com as shown below:
Rohit
thakurr
Hi @karimia
Does the SCUI behaves in the same way both when XM105 is connected to ZCU102 or not? Could you please check the driver version of UART as specified in the link below.  Also make sure you use appropriate SCUI version based on firmware on the board as given in the same link?
https://www.xilinx.com/support/answers/69640.html
Rohit
karimia
Hi, thakurr
In advance, thank you for kind reply.
->It behaves the same way, connected or not. The buttons in SCUI program be disabled when I click any button even I didn't connect the XM105 board
-> I checked version 6.7.0.0(sorry for not English)
-> I have no idea which version I have but I download is from xilinx web site named "rdf0382-zcu102-system-controller-c-2018-3" and I realeased and launched the BoardUI.
Thank you
Best regards
thakurr
Hi @karimia
Could you try with English OS instead Non-English? We have seen issues with SCUI, BIT when using non-english OS.
Firmware version on board can be checked by running @vers command in putty or termterminal. As stated in the AR if this date is 5/17 or earlier, then the 2016.4 version of the System Controller GUI should be used with this board. Otherwise latest versions of SCUI can be used.
Rohit
karimia
Hi, Thankurr
->I can't understand the Non-English and English OS. I'm using Windows, and plus The root I execute the SCUI.exe is C:\Users\user\Downloads\rdf0382-zcu102-system-controller-c-2018-3\zcu102_scui, it's not include any other launguage but English
->I did with the lastest versionbut same results. and Where is the 2016.4 version? I tried to find that version, was not able to download it.
One more thing, I have a doubt with the root appeared when I first executed downloed SCUI. I just put the root default value where I really have vivado in. Is it okay?캡처.PNG
Thank you
thakurr
Hi @karimia
Rohit
karimia
I solved the problem with executing version 2016.4
How could I accect the Answer?
thakurr
Hi @karimia
Glad this is resolved, looks like you have old firmware version on the board.
I am not sure but you should get a seperate button with "Accept as solution".
Rohit
