Participant sschekall
zc702 ddr schematic issue
I'm working on a new design and I'm using the zc702 design as a reference.
according to xtp185-zc702-schematic-ref1-1.pdf : Page9, Page16,17,18,19
xc7xz020clg484 pin D1  is DDR3_DQ0  : But it is  connected to U66.DDR3_DQ3
There are many other DQ pins that are connected strangely.
Is this a design problem?  Or is it something else happening here.?
Why are the DQ[31:0]  signals connected as they are?
Why not connect FPGA.DQ[7:0]  to DDR3.DQ[7:0]?
I checked "The Official Pinout" xc7z020clg484-pkg.txt  Can I trust this?
               Stan Schekall
Re: zc702 ddr schematic issue
As per JEDEC DDR3 and MIG specifications DQ signals can be swapped with in teh byte lanes.
This is allowed and will not create any issues, this is just done for routing feasibility and better SI.
Please refer UG586 design guideliness DRR3  section for 7 series on placement rules
You can trust the pinout given in the site and go ahead safely, but the DQ routing on your board need not necessarily  go for swapping unless your board physics demand,  which will be known to the board deisgners
For more views on pin swapping please refer related topic below
http://forums.xilinx.com/t5/Spartan-Family-FPGAs/DDRx-Layout-MIG-pin-swapping-and-Time-Delay/td-p/162006
http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/Spartan-6-DDR2-Swapping-data-pins/td-p/133472
Hope this helps
Vanitha.
Hope this helps
Vanitha.
Thanks for the prompt, quality answer
