zcu102 Display port Standalone application
Hi all,
I am using zcu102 board and vivado 2016.1
I want to use PS DisplayPort(in tx mode) in standalone application( no Linux os). Is there any example code available to initialize and bring up display port?
No drivers for display port are shown when a bsp is generated
I have copied and used the drivers and sample codes in SDK/2016.1/data/embeddedsw/XilinxProcessorIPLib/drivers/dptx_v3_0 and dp_v4_0/examples
But when compiling the codes I get may errors including
XPAR_DISPLAYPORT_0_DEVICE_ID undeclared
XPAR_XDPTX_NUM_INSTANCES undeclared etc
Re: zcu102 Display port Standalone application
you can find reference design here
http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2016.1
Thanks and Regards
Balkrishan
Can you please help?
Is there a device ID for display port?
If yes, where I can found it?
My xparameter.h contains only below information about display port.
/* Definitions for peripheral PSU_DP */
#define XPAR_PSU_DP_S_AXI_BASEADDR 0xFD4A0000
#define XPAR_PSU_DP_S_AXI_HIGHADDR 0xFD4AFFFF
Am I missing anything?
