dradspd
zcu102: restoring flash with SDK's GUI
I have issues restoring flash on my zcu102. The process was terminiated because of the problem in running uboot.I have attached the vivado log for you to view. Please help.
Thank you.
dradspd
I was able to overcome my earlier issue of uboot. I restored the qspi flash by executing scu102_program_qspi.tcl and performed BIST test afterwards successfully. I proceeded to view the IPI app and ran the list of tests inside teraterm.  Most of tests ran successully except for 9 FMC_HPC1 related clocking and PMOD tests, which are to be expected since I do have the optional hardware attached to the board.
I will close out the thread and pat myself on the back.
dradspd
andresb
Nicely done! We appreciate the feedback that helps other users!
