Visitor darren
zcu104, Ping failed, Could not find regular expression in step 4 of test 7
hi, I am trying to BIT using zc106 board.(XTP498, ZCU104 Board Interface Test ver 3.0)
I also see a guide xtp504-zcu104-setup-c-2018-2.pdf.
when I run PING test, It was failed and I got a this error message.
Error: Could not find regular expression in step 4 of test 7 - "(.*)Pinging\s+192.168.1.10\s+with\s+32\s+bytes\s+of\s+data:"
You can see a all log in PING_Error.txt
I checked DIP SW(SW6), Network configuration, UART serial connection, but I don't know way.
I see a log that 4 of 5 ping command passed but 5th ping  script has problem.
How can I fix it??
plz let me know.
thank you.
Tags (4)
Re: zcu104, Ping failed, Could not find regular expression in step 4 of test 7
Hi @darren,
Please try using Vivado 2018.2
Ensure that no other Terminal program is connected to the ZCU104’s COM ports while the Board Interface Test is running – See XTP504, for details on COM Ports
Only one board can be connected to your PC during the test – Disconnect any other board UARTs or Programming Cables
 If you missed any set-up instructions and experience problems, then please follow these steps: 1. Recheck your setup 2. End any hw_server processes and cycle board power 3. Open Vivado Hardware Manager and test PC-board JTAG connectivity
To perform PING Test below steps are required:
This PING  test requires optional equipment
EZ-11B or EZ-22B remote power switch, setup to IP address of 192.168.0.12
  • Setup details are available later in this Appendix (refer XTP498 v3.0)
If this is not available, the PING test will require manual power cycling
Deepak D N
Reply or give kudo or accept as a solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @darren,
Deepak D N
Deepak D N
