avishai119
zedboard - 3 ADC
Hello, I'm using a zedboard development kit and for a project I'm doing you need to get 3 signals from a signal generator, so I need 3 samplers of ADC's 8 bits,
But I saw that it is possible to connect to the zedboard only one external sample. Do you know a device that can be purchased and using it to connect to the zedboard 3 samples in parallel to sample the signals for my project?
I've attached a picture of the only sample component I've seen connecting to zedboard, AD9467
I need something like that, but 3  like that are working in the same time and connecting to zedboard .
andresb
Hi avishai,
Have you been able to make progress on this project?
There are many FMC boards with multi-channel ADCs, like this 8 channel one:
https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/EVAL-AD7768-1.html
If you give us more details about your application, maybe we can help more.
Andres
