jie
运行官方dpd-smp程序出现异常报错
  • 开环环境:
1、芯片类型:6CG ffvc-900
2、软件环境:Vavido2019.2、Petalinux
  • 问题描述:
运行官方提供的dpd-smp程序,报错如下:
[root@root]# ./dpd-smp -u 0
--- Xilinx Digital Pre-Distortion Software v10.0 rev0
--- Build: Linux SMP: CL2811315
*** mmap to uio driver failed: : Invalid argument
二、配置详细:
  • 共享内存配置
  • 设备树配置
amba_pl@0 {
        #address-cells = <0x2>;
        #size-cells = <0x2>;
        compatible = "simple-bus";
        ranges;
dpd@B0000000 {
clock-names = "dpd_aclk", "dpd_internal_aclk", "s_axi_ctrl_aclk", "s_axi_user_aclk";
clocks = <0x38 0x38 0x37 0x37>;
compatible = "generic-uio";
interrupt-names = "interrupt";
interrupt-parent = <0x4>;
interrupts = <0x0 0x59 0x1>;
reg = <0x0 0xB0000000 0x0 0x4000000>;
dpd_user@B4000000 {
reg = <0x0 0xB4000000 0x0 0x20000>;
dfe_scratch@500000000 {
clock-names = "s_axi_ctrl_aclk";
clocks = <0x37>;
compatible = "xlnx,dfe-scratch-1.0";
reg = <0x5 0x00000000 0x0 0x1000>;
  • 设备节点
  • 驱动映射
[root@root]# pwd
/sys/devices/platform/amba_pl@0
[root@root]# ls
500000000.dfe_scratch/  b4000000.dpd_user/  modalias  power/      uevent
b0000000.dpd/           driver_override     of_node@  subsystem@
[root@root]# cd b0000000.dpd/
[root@root]# ls
driver_override  modalias  of_node@  power/  subsystem@  uevent
此处没有发现uio,对比datasheet的描述,有差异。
To find the particular UIO device associated with an
instance of DPD, check the emebedded linux sysfs directory (/sys/
devices/soc0/amba_pl@0/a4000000.dpd_user/uio) on the
MPSoC and RFSoC devices
  • 内核配置
d)libmetal库
请帮忙分析,谢谢!
