cyx314747
1G/2.5G Ethernet PCS/PMA or SGMII does not work with XCKU040
Has anyone encounter this issue?
This IP cannot startup if Receive GMII Clock Source set to RXOUTCLK.
Otherwise even if Receive GMII Clock Source set to TXOUTCLK, it can only startup from JTAG , cannot startup from QSPI flash.
guozhenp
Need more details.
Maybe you can try the IP core example design or try GT near end loopback mode first.
