siesse
AXI DMA S2MM on zynq with 32bit wide HP port gives saves only half the words,
I got a loose end and i do not like that... mightbe one of you can explain it or give me a hint where to look further.
  1. Design description
On a zynq-7000 we use the AXI dma to get a AXI stream from the PL into the DDR memory connected to the PS. We use vivado 2017.2
Configuration is pretty standard as shown below: the axi dma is connected trough an intterconnect block to the processing system. Both SG as S2MM port are connected.
The AXI dma is configured to take in a 32bit AXI4S stream and push it on a 32bit AXIMM port out
The HP0 port HAS to be configured to 64bit to make it work perferct.
From SW point we use what comes out of petalinux together with the dma-proxy example, the only changes we did was strip out the TX channel.
It is outlined here: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842418/Linux+DMA+From+User+Space
2 Experiment: We init a sw buffer to 0xdeadbeaf and pass it to the dma. We transfer a simple 32bit count from 1 to x we and readback the buffer:
With HP0 configured to be 64bit (good): 0x0000_0001,0x0000_0002,0x0000_0003, 0x0000_0004..
With HP0 configured to be 32bit (bad):  0x0000_0001,0xDEADBEAF,0x0000_0003, 0xDEAD_BEAF ..
3 Actual questioin: why does the design ommits half of the 32bit words if one changes the HP0 port config from 64bit to 32bit?
Notes: we noticed that the device tree (generated from the HDF file) does not change... there is a width parameter indicated there of the dma channel... but probably that points to the width setting of the dma access mm port and NOT the HP port?
2 ) Has anybody a working design with a 32bit width HP0 port?
3) Does anybody know where the S AXI HP0 DATA WIDTH setting gets reflected in sw? Mightbe in device tree or somewere else?
My feeling is there is a lowlevel bug in the Xilinx dma driver or in the hwdef generation... but i could be wrong of course.
Kr,
  Johannes Vanoverschelde
siesse
Found the rootcause:
The FSBL and the FPGA where out of sync. Configuring the HP0 port is done during first stage boot, AFI0 register set.
If one looks in the ps_init.html one finds
AFI_RDCHAN_CTRL@0XF8008000 and AFI_WRCHAN_CTRL@0XF8008014 where n32BitEn "Configures the Channel as a 32-bit interface. 1: 32-bit enabled 0: 64-bit enable"
The HWDEF followed the fpga code nicely. The reason the FSBL got out sync must be some missing build dependency in petalinux. A clean clone of the code and complete rebuild evenutally brought both again in sync. Long live CI :-).
Kr,
  Johannes
siesse
Kr,
  Johannes
