c.fauvel
AXI_IIC Kintex 7 - Not alive ?
Hello everybody,
I am facing an issue with an AXI_IIC block on a custom Kintex 7 board. I use a Microblaze on the FPGA, interfacing with a single device (uDAC from Analog Device). The Microblaze is interfaced to the AXI_IIC block via an AXI_Peripheral bridge and everything is clocked by a 100MHz clock. Everything looks good from the FPGA side (timing requirements successfull, ...).
I have checked the external pull up on the bus and the voltage and everything is fine. When I use a simple code, heavily inspired by the one found in this thread : https://forums.xilinx.com/t5/Embedded-Development-Tools/AXI-IIC-not-generating-stop-condition-throttles-scl-instead/td-p/789126, I am able to view a start condition ... and that's it.
No clock or data can be viewed on the SDA and SCL lines.
I tried to use the Active SDA option to "0" or to "1" but it doesn't change anything.
Do you have any ideas ?
Best regards,
c.fauvel
Hello everyone,
Finally, answering to myself :
I was able to have I2C frames by using this vhdl code instead of an IOBUF.
i2c_sda <= s_sda_out when s_sda_dir = '0' else 'Z';
s_sda_in <= i2c_sda;
i2c_scl <= s_scl_out when s_scl_dir = '0' else 'Z';
s_scl_in <= i2c_scl;
Best regards,
c.fauvel
Hello everyone,
I also add an ILA for the sda_[i,o,t] and scl[i, o, t] signals. The picture below show the idle state of the i2c bus, and also the top wrapper vhdl file.
Best regards,
c.fauvel
Hello everyone,
Best regards,
