Visitor kevin_rowley
AXI slave memory error injection
Can I configure the Xilinx AXI slave memory VIP to inject BRESP/RRESP errors ?
Thank you,
-k rowley
Re: AXI slave memory error injection
HI @kevin_rowley
I do not think this is possible in the AXI slave memory VIP. I believe you need to use an AXI slave VIP (without memory level) if you want to have the control on the signals:
Florent
HI @kevin_rowley
Florent
