m_bridges_etl
AXI4-Stream Data FIFO depth setting not applied
I am trying to use the AXI4-Stream Data FIFO with Vivado 2020.2.
I edited the TDATA width but left the rest untouched.
The depth set in the IP core generator does match the settings used to synthesize the core. I use the default of 512 as shown in the image below. However, this setting is not used to generate the core as explained below.
Looking at the logs it is clear that a depth setting of 1024 has been used. Some of the other settings don't appear to match either.
Starting RTL Elaboration : Time (s): cpu = 00:00:05 ; elapsed = 00:00:05 . Memory (MB): peak = 1431.430 ; gain = 187.641
INFO: [Synth 8-6157] synthesizing module 'axis_data_fifo_0' [e:/VivadoProjects/project_12/project_12.gen/sources_1/ip/axis_data_fifo_0/synth/axis_data_fifo_0.v:58]
INFO: [Synth 8-6157] synthesizing module 'axis_data_fifo_v2_0_4_top' [e:/VivadoProjects/project_12/project_12.gen/sources_1/ip/axis_data_fifo_0/hdl/axis_data_fifo_v2_0_vl_rfs.v:54]
	Parameter C_FAMILY bound to: zynquplus - type: string
	Parameter C_AXIS_TDATA_WIDTH bound to: 64 - type: integer
	Parameter C_AXIS_TID_WIDTH bound to: 1 - type: integer
	Parameter C_AXIS_TDEST_WIDTH bound to: 1 - type: integer
	Parameter C_AXIS_TUSER_WIDTH bound to: 1 - type: integer
	Parameter C_AXIS_SIGNAL_SET bound to: 3 - type: integer
	Parameter C_FIFO_DEPTH bound to: 1024 - type: integer
Inspecting the .xci I found these 2 settings:
        <spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_FIFO_DEPTH">1024</spirit:configurableElementValue>
        <spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.FIFO_DEPTH">512</spirit:configurableElementValue>
Am I correct in saying that this is a Vivado bug or at least a bug in that IP? The main reason that this issue concerns me is that the BRAM usage is doubled which I cannot afford.
Block RAM: Preliminary Mapping	Report (see note below)
|Module Name        | RTL Object                       | PORT A (Depth x Width) | W | R | PORT B (Depth x Width) | W | R | Ports driving FF | RAMB18 | RAMB36 | Cascade Heights |
|inst/\gen_fifo.xpm_fifo_axis_inst /xpm_fifo_base_inst/\gen_sdpram.xpm_memory_base_inst  | gen_wr_a.gen_word_narrow.mem_reg | 1 K x 84(READ_FIRST)   | W |   | 1 K x 84(WRITE_FIRST)  |   | R | Port A and B     | 0      | 2      | 1,1             |
2 RAMB36 used instead of 1.
Thanks in advance for any feedback or tips. Kind regards,
Matthew
Tags (4)
richardhead
The issue  is that the maximum width of a BRAM is 36 bits. So for a 64 bit data bus you are instantly required to have 2 BRAMs. Hence using 512 addresses would then only be using half of the BRAM.
But it really should limit the size to the one you specify (it might be 512 for a reason).
m_bridges_etl
Thank you for the reply. It is really appreciated. The BRAM on the Ultrascale+ device I am using can do at lease 64 bits from what I have read.
If I override the depth and set it to 256 it is able to use a single BRAM. See below
|inst/\gen_fifo.xpm_fifo_axis_inst /xpm_fifo_base_inst/\gen_sdpram.xpm_memory_base_inst  | gen_wr_a.gen_word_narrow.mem_reg | 256 x 84(READ_FIRST)   | W |   | 256 x 84(WRITE_FIRST)  |   | R | Port A and B     | 0      | 1      |                 |
m_bridges_etl
I am pretty confident that this is a bug. The bug could either be in that specific IP core or in Vivado itself; I am not sure the answer to that.
I am quite new to using these forums for creating support cases. Can anyone advise how I get Xilinx to create a support case for this?
m_bridges_etl
I have managed to find a work around which is not ideal, but could work.
Using the FIFO Generator IP core instead of the AXI4-Stream Data FIFO IP core I am to get the correct results. See the image below.
I configure the FIFO Generator core for AXI Stream mode. I set all the other settings to match what I had for the AXI4-Stream Data FIFO IP core.
The utilization figures when using this method look correct:
Report Cell Usage:
|      |Cell     |Count |
|1     |LUT1     |    20|
|2     |LUT2     |    11|
|3     |LUT3     |     7|
|4     |LUT4     |    25|
|5     |LUT5     |     4|
|6     |LUT6     |     7|
|7     |MUXCY    |    20|
|8     |RAMB36E2 |     1|
|9     |SRL16E   |     1|
|10    |FDRE     |   118|
|11    |FDSE     |    12|
This is not a solution to the original problem, but it is usable.
m_bridges_etl
I am still trying to solve this issue. Does anyone have any ideas, or know how I can get Xilinx to investigate it?
@richardhead does my reply about the BRAM width make sense? I should have mentioned that I was using an UltraScale part. The documentation states "When used as SDP memory, the read or write port width is x64 or x72".
richardhead
Yes it does, thanks.
Maybe I need to re-assess some of my FIFOs..
