vhdlveri123
Aurora IP retransmission
When we are using Aurora IP for re transmission? And i need CRC signal, so should i use Aurora for framing?
rkhatri
Hi @vhdlveri123 ,
Yes you can use Aurora IP in duplex mode which can TX and RX at same time.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
vhdlveri123
Can Aurora Ip transmit and receive at the same time?
rkhatri
Hi @vhdlveri123 ,
Rahul Khatri
