vhdlveri123
Aurora IP testing
I am using Aurora 8/10 B IP for connecting two boards. So initially, I am planning to test the Aurora IP with internal loopback mode using IBERT and then in normal mode after connecting two boards, is this the right way to test?
rkhatri
Hi @vhdlveri123 ,
I would suggest you to use first IBERT to test the board then move to Aurora IP.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
rkhatri
Hi @vhdlveri123 ,
Rahul Khatri
