Aurora - Spartan 6- test bench error
I am trying to send data with GTP transceivers. My S_AXI_TX_TDATA  and M_AXI_TX_TDATA data are different in test bench (attached pic).
even I am not sure about  TXP and TXN data is valid or not.
Why there is no similarity between data as data valid( M_AXI_TX_TVALID) is high.
Thanks!
Can anybody please assist me with the above problem. I am unclear with this protocol.
I want to know how M_AXI_RX_TDATA gets derived from S_AXI_TX_TDATA.
Thanks!
Hi @avinashc ,
Are you using Example design?
Are you using Aurora 64b/66b or Aurora 8b/10b ?
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
there was data latency of some 25 clk. i am getting right data.
Yes,using example design 8b/10b.
