Aurora reset_pb signal in example design
    looking at the Aurora ug074 related to Aurora 64b66b I see that reset_pb and pma_init should be asynchronously applied but in the example design I see that the reset_pb input comes to the support reset logic block through a resampling made with user_clk (coming from transceiver). So should I do the same or can I apply reset_pb input asynchronously?
Hi fcaldi@92 ,
Please follow the Aurora IP user guide for reset.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
