Aurora with QSFP Alveo
Hello
Is there any way that I can get the Aurora design working with an Alveo data accelerator card without any push buttons for the reset_pb and init_pb pins or should I go for the QSFP ethernet design? I have the 40G QSFP link between the 2 cards.
Any help would be great!
Hi @naarayananrao ,
You can write your own logic to control the reset_pb and init_pb pins .It is not mandatory to use push buttons.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
I am using the active high reset in processor system reset IP. Would that be ok or writing logic is the only way to do it for seamless functioning?
Hi @naarayananrao ,
Please follow the reset sequence which is there in Aurora product guide.
Rahul Khatri
