Auroura 64B66B Transceiver Setup
I am trying to quickly setup a loopback configuration for my part (xczu15eg-ffvb1156-1-i) using the Aurora 64b66b IP in Xilinx Vivado 2019.2 for the Zynq Ultrascale+. I was wondering if Xilinx has any example designs that use the transceiver capabilities of the aurora 64b66b IP. Namely, information on how to setup the transceiver/clock/reset/etc pins properly (in the vhdl architecture and block design). If nothing exists for my current setup, are there any example designs for different part/FPGA combinations that I could build off of?
Kindly,
Anvar Akhmedov
Hi @aakhmedov ,
Please refer to "example design" Section of PG074.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
I setup a design using Xilinx Aurora 64B66B IP as well as my own waveform wrapper IP (migrated from Vivado 2015.4). I didn't get any errors during synthesis or implementation. But upon analyzing my implementation, I can see that the tx connections are not setup. It seems that the rx connections are created however. The log file associated with this run is attached.
I am attaching an image of my implementation. You can see that that receive side pins are connected (on left) but the transmit side isn't connected at all.
Please check the source codes to confirm if the top modue output pins TXP/TXN are connected to GT submodule TXP/TXN finally.
