Harish_Algat
BLOCK ROM
How I generate 2046*64 BLOCK ROM ?
pthakare
Hi @Harish_Algat
You have below options
#1 Use the block memory Generator IP under the IP catalog.
#2 Use the XPM_MEMORY_SPROM macro. Instantiation is available in UG974
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug974-vivado-ultrascale-libraries.pdf
#3 use the inference method , refer to synthesis user guide UG901
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug901-vivado-synthesis.pdf
With these method you will be able to implement the ROM using block RAM resources in the device.
pthakare
Hi @Harish_Algat
pthakare
Hi @Harish_Algat
Harish_Algat
I am not able to edit that option that is why I have raised the query I am using 2019.2 vivado.
Harish_Algat
Hello I am not able to edit these options
pthakare
Hi @Harish_Algat
Share your IP Screenshot?
Are you using the BRAM controller mode ? If so the parameters are propagated from master .
Please check the product guide
https://www.xilinx.com/support/documentation/ip_documentation/blk_mem_gen/v8_4/pg058-blk-mem-gen.pdf
Harish_Algat
That solved my problem...Can you tell me how can I implement 8K*64 Block ram
