raksssss
BRAM - Simple dual port ram outputs are junk
I am facing a strange issue where my BRAM outputs are getting corrupted on hardware even If I write constant data to the memory, I get corrupted outputs from the memory along with actual data. 0400_0400_0400_0400_0400_0400_0400_0400 is the constant HEX data I am sending, I get outputs 0400_0400_0400_0400_0000_0400_0400_0400 etc junk values are coming. I see any of the 16 bit word is getting corrupted other than 0400.
Image is attached for the same showing BUFFER_2 output getting corrupted.
Could anybody tell what might be the issue for this kind of behavior ?
BRAM depth = 40,000, Width = 128 bit, Write clock =300MHz, read clk =122.88MHz
Platform: ZCU111-Evaluation Board(xczu28dr-ffvg1517-2-e)
BRAm output other than 0400BRAm output other than 0400
drjohnsmith
the issue is probably your code,
if you can not share all the code,
make a demonstration that shows the same effect,
you will either spot your problem, or you can share that code with the forum,
vitalik_zx
Hello. In fast check you can maximum zoom your diagram. On write or read (I don't remember ) the edge is shifted on 100ps maybe you problem related to this.
