ali_farahany
BRAM UTILIZATION PROBLEM
I have wrote a ram block forZYNQ-7020 FPGA. The issue is that its BRAM utilization is higher than my expectation. I expect 32 and 40 bram clock for this RAM Block but the utilization is higer.
RAM BLOCK:
`timescale 1ns/1ps
module dbram #
( parameter DWIDTH=18
, parameter AWIDTH=20
( input clk
, input we, sel0, sel1
, input [AWIDTH-1:0] addr
, input [AWIDTH-1:0] addr1
, input [DWIDTH-1:0] di
, output [DWIDTH-1:0] dout
, output [DWIDTH-1:0] dout1
reg [17:0] ram [0:40959];  // reg [17:0] ram [0:32767];
reg [DWIDTH-1:0] read_a;
reg [DWIDTH-1:0] read_a1;
always @(posedge clk)
begin
if (sel0 & we)
ram[addr[19:2]] <= di;
read_a <= ram[addr[19:1]];
read_a1 <= ram[addr1[19:1]];
end
assign dout = sel0 ? read_a : 32'b0;
assign dout1 = sel1 ? read_a1 : 32'b0;
endmodule
the Utilization:
 Actually i expect 32 and 40 BRAM block consequently. But as you seen it is 36 and 72 and it runs me out of resources.
 Could anybody help me?
miker
You can try the RAM_DECOMP synthesis attribute.  Please reference the Vivado Design Suite Synthesis User Guide (UG901; v2020.1; p 60).
In your case, you would want to modify the following line from:
to:
(* ram_decomp = "power" *) reg [17:0] ram [0:40959];  // reg [17:0] ram [0:32767];
This will result in the following:
Please Reply, Kudos, and Accept as Solution.
