Samosia
BRAM read problem
I am using ZCU104 board, Vivado to program the device and ILA to evaluate created system. I encountered problem during reading content from BRAM.
BRAM configuration:
Mode: Stand Alone (address interface with 32 bits) - 2 clock cycles latency
Memory Type: True Dual Port Ram
Port A: Write First
Port B: Read First
(Write/Read width: 32, Write/Read depth: 256)
At first I write some values to the BRAM using port A and it looks ok (address changes on rising clock-edge). Fragment below:
After that I read values from BRAM using port B (address changes on rising clock-edge). Fragment below, the same addresses like on previous picture:
I don't understand why reading value changes after every 4 clock cycle and not on every clock cycle when enable is on. This behaviour causes skipping proper data for most of the addresses. What can be the reason?
hpbhat
Here, it looks like you are using different frequencies for CLKA & CLKB ports.
You can open example design of Block memory Generator IP & run the simulation to check the behavior of the IP.
With Regards,
HPB
