larshb
BUG: Aurora 64b/66b mmcm_not_locked inverted when ticking "generate Aurora without GT"
Title pretty much sums it up. Whenever you instantiate an Aurora 64b/66b from the IP-catalogue (not in block-design) it works as expected. However when ticking the "generate Aurora without GT" option (and instantiate the GT-wizard separately) and regenerate the support logic the signal "mmcm_not_locked" is inverted. Or rather it is not inverted as opposed to when using the "with GT" option, hence it should be called "mmcm_locked" in this case.
I am using the version Version 12.0 (Rev. 1) of the IP, Vivado 2019.2
rkhatri
Hi @larshb,
Yes your understanding is correct. You can check this file:
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
rkhatri
Hi @larshb,
I am not able to see the signal "mmcm_not_locked" when "generated Aurora without GT" .
Rahul Khatri
larshb
It is routed from the GT submodule from the shared logic <ip_instance>_support.v (and is needed as input on a Chip2Chip cores)
rkhatri
Hi @larshb,
Rahul Khatri
larshb
Ok, hopefully it is the only bug, as I can remedy it simply by inverting the signal again.
Is fixing it of any concern to Xilinx?
rkhatri
Hi @larshb,
I will take this to development team. Thanks for your finding.
Rahul Khatri
